soundquest 10 Posted April 22, 2014 My '92 Corrado is grinding bad in normal upshifts going into 2nd gear. Does it on every shift now unless I let the RPM's go down before shifting into 2nd. I have read a ton on this and looks like this is a common issue. Anyone else have this same problem and find that it was NOT the synchros (I know, wishful thinking on my part, but had to ask)?. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 22, 2014 What's the mileage? Have you checked the oil level? Does the bite point feel low or change? It could be syncros but it could also be clutch, clutch hydraulics, old gearbox oil, bad shifter alignment, worn engine mounts etc... Quote Share this post Link to post Share on other sites
