will87cab 10 Posted April 29, 2014 Hi I'm after a complete early electric window wiring loom. Needs to be complete from fuse box to control module to switches n motors don't need any of the motors, switches or control module just the wiring must be from a early car with switches in the door cards. Thanks Will Quote Share this post Link to post Share on other sites
StueyB 0 Posted April 30, 2014 Can probably help with this. You are basically after both door looms then essential and the main one for the fusebox to the control module. There are other wires as part of both looms so they will come whole as they are, assuming i can find all you need. Quote Share this post Link to post Share on other sites
will87cab 10 Posted May 1, 2014 Yeah that's right. I think there is some speaker wires and some stuff to do with Central locking taped up together Quote Share this post Link to post Share on other sites
will87cab 10 Posted May 7, 2014 Hi Stuey B You had any luck finding the loom Quote Share this post Link to post Share on other sites
