Supercharged
Brand New Genuine VAG LHD Heater Fan 191959101
Left Hand Drive Models only (and non A/C)
No resistor pack as this is a separate part.
Brand new boxed VAG unit made by Temic
Can be collected at Stanford Hall or posted.
55
List Date: 5/1/2014
For more info, click here to view the original listing: Brand New Genuine VAG LHD Heater Fan 191959101
On Sale For: ?55.00
the-corrado-forum
Mobile friendly version: Brand New Genuine VAG LHD Heater Fan 191959101
surely you can slide the motor out and fit into a rhd casing? - I've taken them apart before, takes a bit of ingenuity to remove the fan but it's perfectly possible. I'm assuming the motor spins in the same direction, from memory the fan blades look to face the same way.
just checked, LHD is a mirror image of the rhd version, so the fan blades are reversed and the motor must spin the other way - bu99er!
Edited by davidwort
Correct David, I planned to have a go at swapping it but I have 2 new VAG RHD ones so seems a shame to potentially break this... I know there are a few on here with LHD cars but then again most will have AirCon too.
Thanks both for confirming the difference. Supercharged - have you plans for both of your new RHD ones?
I'm keeping them as spares mate - you should be able to get a RHD one new though for not much more than the price above...
Go to a Valeo dealer (usually much cheaper than Euro / GSF) and quote 698031 which is RHD
OK thanks m8! & very helpful with the part number, much appreciated :)
Double Post.
Ian.
you can say that again,
you can say that again...
can I call you double post Ian from now on :)
