mofish66
early corrado , excellent condithion
Time has come to sell im afraid as am losing storage at the end of the summer , car has only been on the road a handfull of times in last few years , only really to check everything is ok as its been being restored / upgraded over last five years.really nice car that i wish i had time to use and not have it sitting in garage year after year , hopefully listed most stuff below but any questions call me
Cd full of photos during stages of work carried out inc all photos along the way of engine rebuild
Early volkswagen corrado 1989 16v Kr
rare Quarts grey metallic (corrado only colour)
153000 i think,car has full service history in original vw service pack with manuals etc ,two sets original vw keys
lots and lots of old mots ,receipts etc work which has been done has been carried out between 2009-2013 with car only doing a few hundred miles in this time
Engine
taken out in 2010 and fully rebuilt with a 2lt bottom end and recon 1.8kr head ( this is a popular conversion retaining kr cams and bigger inlet manifold with stronger bottom end resulting in more powerful engine)
new stainless steel braided fuel lines
new waterpump,cambelt kit , pulleys, tensioners etc
all new gaskets throughout inc metal head gasket set
new alternator + P.A.S . and all new belts
new throttle cable and all sensoers replaced
new full samco blue silicone hoses throughout
new distributor ,rotor arm and NOLOGY HT leads and spark plugs
Mocal13 row oil cooler installed with thermostatic adapter plate and stainless steel braided hoses
new battery
full oils and coolant change with mobil 1 fully synthetic inc gearbox and g12 coolant
stainless steel powerflow exhaust system
Chassis
New in 2013 JOM fully adjustable ride height and damping coilovers , ( these are expensive and not the cheap ones you pick up on Internet , makes a massive difference in ride and handling , these arent crashy like the cheap one and damping is brilliant) , inc height spanners and damping keys etc
Front strut brace
New top mounts
New bushes throughout
New seamwelded wishbones (originals are known to be a weak point )
New track rod ends
New wheel bearings
new front calipers, refurbed rears
new EBC drilled and grooved discs front and rear
EBC greenstuff front pads and pagid rears
New 5.1 brake fluid
new toyo tr1 tyres
Aluminium wheel spacers , 10mm fronts , 20mm rears
Interior
full retrim of seats , doorcards etc
New headlining
carpets cleaned
four point harness,s
fire ex in passenger footwell
all electrics working , mfa computer all works , sunroof tilts and slides , spoiler raises and goes down automatically as it should and also can be worked manually via switch
Exterior
All pretty standard really , Original wheels have been painted black and come with all centre caps ( these arent on in photos as was setting ride height)
obviously it sits alot lower than standard but this can be changed to standard height in mins
No rust on car whatsoever , on top or underneath
i had front and rear bumper painted as were stone chipped and these are perfect,lower front spoiler all intact and unmarked . there is a couple of minor dents on car although a dent doctor could sort these it hasn't really ever bothered me enough to get it done ( and im really quite fussy ).at the end of the day its nearly 25 years old other thing i would have liked to have got round to doing is replacing soundproofing on underside of bonnet , this has been taken off but nothing put back as yet ,new windscreen fitted , has metal pressed plates and plastic ones
comes with some spares ie , bits of trim , spare head, spare gearbox , lots of small engine parts ,set of fk coilovers,
at present the car is not mot d or taxed but can get it mot d once somebody has seen and bought it , dont want to get it done until then as if it dosent sell then new storage will have to be found and ill keep it without it going on road
poss px for motorbike ???
any info you need call me on 07908063501
Paul Wood
List Date: 5/8/2014
For more info, click here to view the original listing: early corrado , excellent condithion
On Sale For: ?3,000.00
the-corrado-forum
Mobile friendly version: early corrado , excellent condithion
