buttles 0 Posted May 9, 2014 Hopefully this is a simple one! The switched live feed to the radio has a leak on it. ( I am using this to power my new DAB ariel) When all off/key out there is 0.64v which is flattening the battery. New ignition switch (OEM) is the same. Pulled all fuses and none kill it. I gather the feed is direct from the ignition switch but was wondering if it was backfeeding from the permanent live feed via the headunit? I haven't disconnected that yet to check so was looking here to see if anyone has seen this before? Now prays this isn't a known problem!! Quote Share this post Link to post Share on other sites
