somersetdub
High Spec/rebuilt Aqua Blue, Recaros etc etc
Well, here goes.. I've been contemplating selling the car for a few weeks as I fancy a change. I have owned the car since October 2009. Please see the build thread also.
1993 Aqua Blue Vr6
156k on the clock
Long Mot, short tax
STACKS of service history, going back to the nineties and service book/wallet etc.
This car has benefitted from a relentless stream of time and money being spent on it in my ownership as follows:
Engine - remanufactured Vege engine fitted 2000ish miles ago. Run in and had it's first oil change at 500 miles. Running very sweetly.
Vibratechnics front mount
Vibratechnics gearbox mount
GB Poly rear engine mount
New Bilstein B12 suspension kit
New Bridgestone potenzas all round
Front discs and pads on 288mm conversion
- Pagid
New cv joints all four
TT wishbone bushes - genuine
Powerflex front wishbone bushes
New alternator
New starter motor
New spark plugs
Magnecor leads
Eibach roll bars
New track rod ends - genuine
New ball joints - genuine
New handbrake cables
Uprated headlight loom (new)
Recent genuine radiator.
DG fan mounts and slimline fan
Alloys have just been powder coated
New wheel bearings
New Bosch silver battery
New thermostat and all plastic coolant housings replaced.
New oil cooler pipes
New top mounts
Group buy headlight switch
Mk4 golf handbrake lever
New wiper linkage
Subframe, wishbones, hubs etc powder coated
New ignition switch
Replaced fan resistor with a good used one
New Toad alarm and immobiliser
Schimmel Performance lightened flywheel
Mk3 Golf steering rack - no play.
New Sachs clutch
Gruven billet aluminium crack pipe
Mk4 coolant bottle
Mk3 Golf wiper motor
New Genuine front cross member mounts
New water pump
New aux belt
New aux belt tensioner bearing
Re-taped wiring loom
New clutch slave cylinder
New Goodridge braided hoses
Powerflex rack mount
Magnex cat back exhaust system
Full leather recaros - electric and heated and working
Genuine rear axle bushes fitted 7k ago.
Vr6 private number plate
All new coolant temp senders
New air intake temp sensor
New oil temp and pressure switches
New subframe and wishbone bolts
New wiper interval relay
New genuine spring top caps
New genuine roll bar links
New injector seals
Mk4 golf rear calipers with genuine discs and pads
Currently fitted with a k&n cone filter, but I do have an undamaged standard air box available and spare maf.
Alpine CD/USB head unit with alpine speakers front and rear 6x9s, neatly fitted.
There is also a bonnet bra, which came with the car when I bought it, but I've never fitted it.
The list goes on.
I would really like anyone who is interested in the car to come and view it before making any offers etc, so that an informed decision can be made.
The bodywork looks stunning when all cleaned and polished, but does have age related marks here and there and the odd bit of lacquer peel if you look closely. I had the front wings, bumper and bonnet painted when I bought the car, but there are a few stone chips to the front now. To be honest, I was always glad the body isn't completely perfect as I bought the car to be driven. The interior is pretty much mint, the recaros are in very good condition and I had the drivers bolster repaired to a high standard.
The car has been driven since the rebuild, so suspension components etc, are now a little dirty.
The spoiler works fine, but the sunroof has stopped working. It used to work fine, but gradually became slower before giving up - I believe the mechanism is stiff and needs removing, lubricating etc as you can hear the motor trying to work and it spins freely when removed from the cassette.
Everything else works fine and there are no faults on Vagcom.
Please call 07730526473 to discuss any further.
I'm not in a hurry to sell and I would be quite ok with keeping it for another year or so if no one wants it.
£5500
Theo
I have many, many more photos available upon request.
Edited by somersetdub
