greenveedubb 0 Posted June 1, 2004 Hi! I'm new to the boards. I've had my G60 corrado for about a 1 1/2 years and had the chance to have a 1.8T (AWP) installed. The car is running under digi-1. I was wondering who has the same set-up as mine. I'm having problems w/ setting the right air/fuel and boost on a stock turbo. The car is still in the shop but I stopped by the check it out. It's running a bit lean on 14 psi. The mod done was a GIAC or Garret Stage 4 G60 chip. How did you guys set yours up? Did you guys use a wideband? Thanks. Quote Share this post Link to post Share on other sites
aposegil 0 Posted June 1, 2004 mate u need to get something like the HKS APEXI controler that will fuel extra The g60 ECU isnt realt built to run against boost as with the charger its very constant and with turbo u can just adjust with a turn or a valve Also it will be alot safer for ur engine :) Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted June 1, 2004 you could also try talking to jabbasport they ran a 400brake 20vt in there red rallye on digi 1 also volkspeed use this set-up but the only ones i saw where supercharged Quote Share this post Link to post Share on other sites
Dubcharged 0 Posted June 1, 2004 Hi Mate Contact Danny from the US side of SNS Tuning in ATL, he will be able to help you out no problem. mailto:[email protected] Quote Share this post Link to post Share on other sites
greenveedubb 0 Posted June 5, 2004 Thank you for all your inputs! Quote Share this post Link to post Share on other sites
