greenveedubb
1.8T with G60 Management
Hi! I'm new to the boards.
I've had my G60 corrado for about a 1 1/2 years and had the chance to have a 1.8T (AWP) installed. The car is running under digi-1. I was wondering who has the same set-up as mine.
I'm having problems w/ setting the right air/fuel and boost on a stock turbo. The car is still in the shop but I stopped by the check it out. It's running a bit lean on 14 psi. The mod done was a GIAC or Garret Stage 4 G60 chip.
How did you guys set yours up? Did you guys use a wideband? Thanks.
mate u need to get something like the HKS APEXI controler that will fuel extra
The g60 ECU isnt realt built to run against boost as with the charger its very constant and with turbo u can just adjust with a turn or a valve
Also it will be alot safer for ur engine :)
you could also try talking to jabbasport they ran a 400brake 20vt in there red rallye on digi 1
also volkspeed use this set-up but the only ones i saw where supercharged
