Richarddarrenb
help required, voltage readings at sunroof multi plug
Having issues getting my sunroof to work, anyone with an electric tilt and slide roof fancy taking voltage readings at the sunroof multi plug for me?
I've got the following, numbered on wiring plug and wire colour:
6 brown earth
5 red white 12v at ignition
4 red yellow 9.6v at ignition
3 green 6v on ignition 12v with switch pressed to slide open
2 yellow 0v on ignition 12v with switch pressed to tilt up
1 blue 0v on ignition 12v with switch pressed to slide closed
