RACK
Will it fit?
I'm gonna service the car later, just needed to know if a standard G60 oil filter will fit due to me having the sandwhich plate for the oil cooler on there?
Cheers
RACK
have you got BOTH an after market sandwich plate, AND the original one on there? If you have it'll be VERY tight to get a normal oil filter in there...
If you only have one or the other, then it'll be the same as being stock as the 2 oil cooler sandwiches are about the same size give or take a mm or 2... 8)
Nope! - it will tho if you hacksaw the hex off the bottom, only takes a min and then spray some hammerite over the bare exposed metal!
Thanks for the replies.
I'm not sure bout the plates because I didn't fit it, but the filter on there at the min doesn't have a hex on the bottom, at least I don't think it does? :oops:
I'll soon see when I get home.
Cheers
RACK
