inkarnata
Still messing with my fusebox....
So in trying to track down various issues . Now I have a no start condition...I'm guessing fuel pump.. But every picture I see of the fuse box has 30 30b jumpered together. But I have one of these (not my picture)
Is still supposed to be jumpered or is there something else that should be in there?
The red block is the jumper, fuel pump should be in the y2 position (near the corner, out of shot to the left in the above pic).
Figured it out. Fuel injectors weren't plugged in. Normally, they go to Z1, mine do not, the plug they they are on is a single plug and fits into the 30-30b jumper, Z1 is a wider plug.
Getting my issues worked out an causing new ones in the process. Got the cluster working, gauges and all, sunroof and windows still work.
Current problems:
No interior instrument lights, turn signals on dash (lights themselves are working)
Drivers side low beam not working, high works.
Spoiler is reversed....goes DOWN at 45 and comes up when you first come to a stop.
Got instrument lights back, albeit being on all the time the car is on, low beam is fixed, got back-up light switch to install tonight and new bulbs all around. We'll see whats up with the spoiler when I get to drive it again.
