Jim Bowen
FK De-badged Late 3 Slat Front Grill - SOLD
FK De-Badged Grill. Centre top clip slightly broken (see photo), Doesn't affect fitting. Some slightl marks on it from storage, but generally looks tidy when fitted, I had planned to have it painted. Got 4 grills sat around so selling one, might need the other 3!!! lol
List Date: 8/19/2014
For more info, click here to view the original listing: FK De-badged Late 3 Slat Front Grill
SOLD
the-corrado-forum
Mobile friendly version: FK De-badged Late 3 Slat Front Grill
arrggghhh the pain lol
im hunting for a grill for my early valver but dont think this will fit as the tabs will be in different places :(
have you got an early one in the others you mention by any chance? (if your willing to part with it)
thanks
I have a couple of these and they fit mine which is an early car.Don't think there is any difference
I thought there was a way of fitting a late grill to an early car.
i think you can with a bit of butchery & some silicone sealant or similar
IIRC the difference is that the late grill has 3 tabs on the bottom (1 central & the other 2 equidistant from the centre) whereas an early grill only has 2 tabs which are about 1/3 of the way in from each edge.
my valver has a 'modified' late 3 slat grill but im hoping to source the correct early version - however im not keen on paying £75 to heritage for it :(
Here's a couple of pics of mine fitted (bad quality) of course my car could have a later slam panel on it which could explain it. But i had a G60 with a late OEM grille fitted.6uhyhuva.jpg3u6e9ume.jpg
Just hacksaw the middle tab off the bottom and sand it smooth. Literally takes 5 mins. It will still fit to both early and late slams.
Thanks clumpy & cazza!!!
I thought all of the bottom tabs were in the wrong place
Brilliant info & handy to see pics.
Jim - if it would be ok with you can i please put a potential 'yes please i will have it' on your grill & i will confirm tomorrow once ive double checked i have to replace the one i have?
I'm going round to get a pic of Brembo's for Jamie and it's stopped raining at the moment
Here is a couple of better pics 2y6a3e8u.jpg top clips abynupuj.jpg lower slam panel for 3 apps for the ones on the bottom can only assume my car had a Late slam panel fitted when it was painted gu2amu9u.jpg
