g0ldf1ng3r 16 Posted August 21, 2014 I received my new heater blower motor today :) It is much bigger than i was expecting, hopefully fitting it wont be too much trouble If anyone is interested i get a good deal from ebay, linkage below.... http://www.ebay.co.uk/itm/BRAND-NEW-O-E-HEATER-BLOWER-MOTOR-VW-CORRADO-192959101-/321157973200 Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted August 21, 2014 Exactly the same one I bought, fitted fine and works a treat! Ian. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted August 21, 2014 Exactly the same one I bought, fitted fine and works a treat! Ian. Thanks for your post Ian, very reassuring. Was fitting not too difficult? ive a guide & it looks fairly simple Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted August 21, 2014 The car was at my mechanics at the time so got him to fit it, only a few minutes from memory though? Ian. Quote Share this post Link to post Share on other sites
Jim 2 Posted August 21, 2014 Piece of ****. Remove the passenger side under tray, disconnect the power connector (and then remove the resistor pack as you'll need to transfer that over) then reach round the back of the fan for the latch to undo it, twist and drop it out and insert the replacement. 15 minute job max. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted August 21, 2014 Piece of ****. Remove the passenger side under tray, disconnect the power connector (and then remove the resistor pack as you'll need to transfer that over) then reach round the back of the fan for the latch to undo it, twist and drop it out and insert the replacement. 15 minute job max. Jim you are a gentleman thank you - a job for the weekend then as it was howling when i was trying to clear the screen this morning Quote Share this post Link to post Share on other sites
Langsam 10 Posted August 23, 2014 You are a life saver! Mines been annoying me for the last few months squeeling and groaning depending on speed! I'm buying one of these next week. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted August 27, 2014 You are a life saver! Mines been annoying me for the last few months squeeling and groaning depending on speed! I'm buying one of these next week. excellent, someone made use of the link :) happy to help Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted August 27, 2014 update - ok, i fitted my blower on sat & TBH the timeliest part was trying to find the 'locating tab' which stops the motor from rotating out. fortunately a quick look in the bentley manual & it showed the tab is at the rear & you just need to ease it down & then the motor rotates clockwise about 1/4 ish of a turn & drops out once the motor is out you also need to unclip the metal front part which has the connector & thermal fuse behind it so as to reuse on the new blower slip it back in place, connect up & no more whining motor when trying to see out the misted windows.....& it blows like a tornado compared to the old unit :D Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 27, 2014 I bought one of those a while back, the fan blades weren't pressed onto the shaft quite right and it rubbed on the surround when fitted, a bit of careful pressing and trial and error and I fixed it though and it ran great, just something to look out for. I did explain this to the seller and they did say they would check their other stock. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted August 28, 2014 I bought one of those a while back, the fan blades weren't pressed onto the shaft quite right and it rubbed on the surround when fitted, a bit of careful pressing and trial and error and I fixed it though and it ran great, just something to look out for. I did explain this to the seller and they did say they would check their other stock. thanks for the info davidwort. i will keep an ear out for any such kind of noise but all seems lovely jubbly so far Quote Share this post Link to post Share on other sites
