Red-VIII
Dashboard LCD not coming on
Hi,
The corrado i am driving was left standing for a long period of time and the battery went dead. I have sinced fixed the car up and all the electrics work apart from the LCD display on the dashboard. When i turn the lights on in the car the LCD displays gets back lit but nothing is displayed.
Is this a simple problem to fix? do i just need to reset something?
The LCD display / trip computer did work fine until the car was left standing for 18 months.
Any help would be appreciated.
the same happened to me in my case i took the clocks apart and removed the lcd module (attached by 4 torx screws from the rear) cleaned the contacts put it back together and its worked fine ever since. the torx screws were also quite loose which wouldnt of helped
