2.016V
Revs sticking one up to temp
This afternoon my ABF decided to throw a wobbly, when it got warm the revs started sticking at 2k and won't drop down at idle, but sometimes idles briefly like it should then revs up itself back up to 2k, can rev freely but is a little rough and is abit lazy getting back to 2k at idle.
Relays have been done, checked vac lines, throttle cable fine, TB cleaned, *ISV cleaned and working.could it be something to do with the Throttle Position Switch, I have been meaning to do the ecu/coolant temp sensor for a while aswell, would this have this effect if it has failed as it started when it was up to temp.
Thanks in advance*
