Stifko
2.0 16V ignition
I apologize for my ignorance of
English, Google translator to help me, I
am from Czech Republic I bought
Corrado and the next morning I
images. When you first turn the
engine started, after a while began to
go irregularly on 3 cylinders and
filling. then he did not go start. When
you wait a minute, approx. 2-3
minutes it starts again again for a few
seconds. Candles are wet, so I guess
that to dry thoroughly so it starts. I
put the car into the garage to heat, I
opened the distributor cap and it was
wet, cleansed I have contacts,
degreased and had everything worked
as it should. This morning I will come
again and the same thing starts, after
a few seconds. will go to 3 War and
off. Then again it do not start. Not
after all normal humidity to go to the
distributor?
Edited by Stifko
first things first I would change the distributor cap
its hard to understand the google translate
První věcí, první bych změnit víko rozdělovače
jeho těžké pochopit,Google
you need to determine if the misfire is on just one cylinder. with it running pull the ht leads off the "candles" one at a time, if one comes off and no change occurs to the engine this is the problem cylinder.
there should be no water near the distributor. dry this out, it should stay dry, a small squirt of wd40 will help.
check for air leaks on inlet side.
