imyhamid
Cutting out can anybody give advice to a newbie
Hi to all you corrado owners, I have a 1994 corrado Vr6 which every so often cuts out at low revs mostly when slowing down. I wonder if anyone could give me any advice. Iam in the northwest and wonder if there is anyone in the region with a vag-com that may be able to connect me up and sort out the problem or is ther an other way to sort it out. Cheers any help would be great. :D
yeh some of the things do seem similar it has only just started to happen and it only happened a few times what do you advise me to do first. Probably the best and cheapest method to resolve the problem. Thanx for the help
get it VAG-COM checked will be a definate help......just so as to rule out any dodgy sensors............thats about all i can suggest off the top of my head :wink:
