90corradog60
few newb q's - clutch & temp light
hey i've always loved corrados but i am new to owning one (90 corrado g60). my clutch has to be pressed really hard into the floor to put it in a gear, does this just need an adjustment or what? one other thing is my temp gauge light flashes sometimes but my temp gauge is really low, not on the needle but low this a common little flaw or what? thx for the help.
temp gauge light also is a water level warning.... try topping up the coolant so that it's between the 2 marks on the expansion tank and this'll almost certainly cure this one... 8)
The clutch problem sounds like you either need to bleed the clutch slave cylinder (it's a hydraulic system - no cable to adjust) or you may need to replace the slave cylinder if this doesn't work... :? Not expensive, or difficult to do... 8)
Oh, and welcome to the forum... 8)
