ZackM8
Installing a gauge pod and gauges
Can anyone give me a basic rundown on how to do this... I have an American corrado with my pod that fits on the drivers side side windshield thingy, and i have a boost gauge and voltmeter to hook up.... can anyone give me that basic rundown and easiest was to get that dash apart and such to make this work and the best hose to tap into for the boost gauge thanks
like this then download.php?id=3158
Basically you need to mark up where the pod goes, remover the trim and screw it all together with the wire going into the trim and down the side of the dash into the fuse area, from there you can tap the volts and hock up the boost gauge to the dash instrument cluster
a litle bit yes, the instruments need to come out, (easier if you remove the steering wheel)
now what is the best vacuum hose to tap into? can you take a picture of it ? and what is the easiest way to get that hose into the engine bay ....
you tap the boost gauge of the hose that goes to the cluster so there is no need to go into the engine bay
