monVR6
Clutch problems . .
Morning all. OK - came out this morning and my clutch pedal has sunk to the floor. It's done this before, but seemed to correct itself - especially with the old toe under the pedal trick. I think it's the slave cylinder - are there any threads on how to fix this - apologies, being at work I can't check. Also, is it easy, what's involved - what does it look like etc etc??
Thanks all - at least it's a nice day !!
Yeah...
I had the same problem in the beggining of this year.
I coulnd´t change gears without scratching the gearbox ( outch!! ) :shock:
And there was lots of oil on the matt! :roll:
It was the slave cillinder who sad BYE! BYE! :lol:
Check first for signs of a leak - fluid ontop of the gearbox and check the level in the resevoir
You might not see much tho as they leak internally at first...
