Storemansteve
Corrado VR6 - Blackberry N reg 1996 - 69,000miles
Most people on the Corrado forum will know of this car as it is a tremendous example of the marque. Unfortunately my friend who stores it for me in his showroom is unable to keep it there any longer, it will not go in my garage as other vehicles are in there and deserves better than living outside in miserable Cumbrian weather.
It will have a new MOT, and the only faults are that the heater only runs on full which needs the fuse changing which I have got but not got done yet(a common fault in many vehicles), the heater dials are not great but I have replacement module and occasionally the ABS light comes on - I have a replacement pump to go with the car so this can be easily sorted if necessary before MOT if it is still a problem and the pump will come with the vehicle anyway.
I don't need to say what an immaculate example this is - you could eat your dinner off the underside it is that clean. Personally I am not a fan of the subwoofer in the boot but it is custom made and can be removed without causing any damage.
This is what has been done to the car:
Since2011 it has been completely stripped the underside and powder coated and re-built it to an extremely high standard.
Spec as follows:
Original factory Blackberry paintwork
INTERIOR
Black leather interior with electric heated Recaro front seats
Factory option gauge pod with voltage and oil pressure
New Heater controls (supplied with car)
Kenwood Mask single CD player but also includes an Alpine head unit with 6 cd changer, 2 Alpine V12 amps driving front MB Quart component speakers and Alpine 10? bass sub housed in a custom made boot install
Cobra Category 1 Thatcham approved alarm
BODY
Custom red tinted rear lights
Clear side repeaters
All black badges
Remanufactured factory spec dealer number plates
Powder coated petrol tank straps
Heat shields all vapour blasted
EXHAUST
Super sprint cat back system with both rear boxes in stainless steel
New genuine VW exhaust hangers
SUSPENSION
H&R Height adjustable suspension ? re-plated and powder coated springs
Bonrath uprated suspension top mounts
New front wheel bearings
New bottom ball joints
New drop links
New track rods and track rod ends
Powder coated bottom arms, sub-frame, drive-shafts, hubs, radiator and engine support
Powder coated rear beam
All new genuine VW bolts, screws etc
Factory speedlines blasted and powder coated
BRAKES
Black Diamond grooved discs all round with Pagid pads
Powder coated backplates
Stripped and painted calipers
Goodridge braided rear brake hoses and genuine VW front flexis
Re-manufactured original brake lines from bias valve forwards
New bias valve
New master cylinder reservoir
New master cylinder to ABS pump pipes
ENGINE
Painted block
Powder coated sump with genuine new gasket
New exhaust gaskets
New inlet manifold gaskets
New cam cover gasket
Blasted and painted inlet manifolds
New water pump
Painted gearbox
Cleaned and re-plated gearbox brackets and bolts
New PAS pump
New auxiliary belt tensioner
Fully serviced with new oil filter, oil, water, PAS fluid, brake fluid by local VW specialist 50 miles ago.
ELECTRICS
New uprated wiring loom
List Date: 1/21/2015
For more info, click here to view the original listing: Corrado VR6 - Blackberry N reg 1996 - 69,000miles
On Sale For: ?7,495.00 (Local Pickup Only)
the-corrado-forum
Mobile friendly version: Corrado VR6 - Blackberry N reg 1996 - 69,000miles
