Will.I.Dub
Coolant sender / cooling questions
I have read the 'definitive guide on here but I'm not clear on a couple of things
Which sender does the temp gauge get its signal from?
Does the run on timer for the aux water pump and fans run on for 10 minutes every time the ignition is turned on and off or is it a function of temperature?
Car is a 95 VR
Thanks
Edited by Will.I.Dub
Temp gauge in the dash should be the yellow sender, the after run of aux pump is done on temp (which might be taken from the blue sender)
Thank you gents (unless Hairyarse is a lady):confused4:
:p Nope, very much a bloke!! lol
(What sort of ladies do you hang out with!! lol)
