cdem
Bleeding the clutch
Just wondering if there is any disadvantage of bleeding the clutch using a syringe on the slave cylinder to push the fluid/air through to the bottle?
Not sure on that one. Was a 2 second job for me doing it the other way bottle to bleed nipple using gunson easy bleed kit
I tried that way however I just couldn't get a pedal. Used the syringe on the slave cylinder and it worked right away. Just wondering if it could flip a seal or anything as i seem to have a leak somewhere
