333 10 Posted February 12, 2015 (edited) Corrado VR6. 83k miles. Flash red "L" reg. This item is on eBay item number : 151587539177 On the L registered August 1993. Genuine Mileage 83,959 with past 11 years mot's service history to back up. VR6's like this are hard to find with low miles and great history and condition. Highlights. This car was owned before me by another VW enthusiast who spent lots on the car doing all the preventive modifications to make the car reliable, safe and up to modern day driving standards. I have nothing to hide so hear is his build thread : http://the-corrado.net/showthread.php?47218-Flash-Red-1993-VR6 Service book stamps, read as follows: 04.5.94 - 11,473 - lex Audi 31.8.94 - 16,000 - lex Audi 29.8.95 - 22,540 - Audi Kent 04.9.96 - 29,725 - Audi Kent 23.7.97 - 34,061 - VW Kent 01.7.98 - 37,781 - VW Kent 23.7.99 - 40,729 - VW Kent 11.9.00 - 46,070 - VW Aberdeen 07.8.01 - 50,315 - VW Kent 14.3.03 - 66,192 - home service 26.11.09 - 72,639 - Volkspeed engineering 04.2.11 - 77,125 - DG AUTOTECH (corrado specialist) 17.2.12 - 80,006 - Tuning Werkes Croydon (VW specialist) 27.2.13 - 81,730 - volkspeed engineering Then documented work I have completed / paid for : 22.3.13 - 81,873 - oil filter genuine VW part. Mobile 1 extended life 10w / 60 Oil = ?108.20 20.8.13 - 82,747 - @ Dorking TUTTS VW/AUDI replaced cam cover gasket. Checked fuel pressure, exactly to manufacture specification. Carried out 3D digital four wheel alignment and adjusted front track. Adjusted both front camber angles. = ?208.51 22.8.14 - fuel hose - changed myself. = ?8.16 14.1.15 - 83,839 @ John Mitchell Racing littlehampton (Corrado specialist and a really good one, what john don't know ain't worth knowing !) Took it there for a once over, they carried out the following : Check fuelling system for electrical and or delivery faults none found. Inspected vacuum and induction hoses for deterioration none found. Checked idle air control system, idle stabilisation valve (ISV), ECU, throttle position sensor, mass air flow sensor, ECU diagnostic codes, (DTC's) - DTC's found relating to MAF short to earth and lambda emissions. Inspected engine wiring harness - all ok however MAF was faulty. Removed ECU and inspected to ensure no damage - none found. Parts fitted : New MAF, Engine coolant sensor, air filter. Re tested Vehicle and all systems where operating to tolerance. Clear DTC's and checked none re appeared. Test drove and carried out final diagnostic check for DTC's - all clear. Also fitted new battery to car as old one was not fully holding charge. = ?1,186.57 29.1.15 - 83,937 - Just tyres - x2 new front tyres and checked tracking = ?109.97 29.01.15 - 83,950 - MOT'd - now expires 28.1.16 - NO ADVISORIES ! Highlights are : 83,959 miles Chains, clutch replaced by DG Autotech (the car is on the front of their web site) Gearbox rebuilt by the bloke next door to DG Autotech DG fast road cams DG remap DG headlamp loom Uprated brakes all round plus hand brake cables replaced - all by DG Very good speedlines and tyres Undamaged 90 mm splitter Jetex exhaust Bilstein B4s all round Numerous bushes upgraded to R32 New Aux water pump New MAF New engine coolant sensor New battery and leads have been change short shifter and the door handle repair kit Cloth interior in great condition Still has original warning triangle in cellophane in rear arm rest. Sunroof works fully Spolier works on switch and at speed. E/mirrors work Alarm is a clifford concept 300 with two blippers with all paperwork / certificate. I have a document folder of history with receipts for work/upgrades over the years totalling ?6,952.48. Ready to drive away and use. bad bits Few age related Stone chips and a couple of small car park dings - the usual for a 21 year old car Heater - the direction dial is a bit stiff in certain positions, but fan works fine. very slight oil leak. ?5,250ono. List Date: 2/13/2015 Location: Surrey, United Kingdom For more info, click here to view the original listing: Corrado VR6. 83k miles. Flash red "L" reg. -------------------------------------- On Sale For: ?5,250.00 (Local Pickup Only) -------------------------------------- Edited February 21, 2015 by 333 Quote Share this post Link to post Share on other sites
