Hassan. 10 Posted March 2, 2015 Good evening guys, This afternoon I decided to adjust one of my coilovers as I noticed it was rubbing on the arch. I then checked the oil. Once I had finished I locked the car via the fob as usual and there was a constant bleep (which the car usually makes if a door/bonnet/boot is left open). However I double checked everything and all was locked and fine! I cant seem to understand why its not working. Any guidance/tips please... Thanks in advance! Quote Share this post Link to post Share on other sites
Hassan. 10 Posted March 2, 2015 The central locking is working fine with the key. Quote Share this post Link to post Share on other sites
coullstar 0 Posted March 9, 2015 Hi, have you tried syncing the fob with the car. I had some issue last year similar and this worked. They have just returned though. Quote Share this post Link to post Share on other sites
Hassan. 10 Posted March 9, 2015 Hi, have you tried syncing the fob with the car. I had some issue last year similar and this worked. They have just returned though. It started working again, then I raised the car a few days later to adjust the coilovers (2nd time)...after this it had the same problem. Il give it a few days it might start working again. Bizarre, as it does unlock the car/deactivate immobiliser/panic button works still. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted March 9, 2015 I have just had my car in the garage having the brakes done and I now have the same problem (also have a cobra alarm) - multi beeps on locking. On Wednesday I am dropping it back into the auto electricians that fitted alarm to check it so interested in seeing any replies as to cause! Quote Share this post Link to post Share on other sites
coullstar 0 Posted March 9, 2015 Ask him how you would disconnect it as well please or at least so the car wouldn't be immobilized. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted March 9, 2015 Ask him how you would disconnect it as well please or at least so the car wouldn't be immobilized. Isnt there a section on doing that in the instruction manual? Sure I saw something Quote Share this post Link to post Share on other sites
Hassan. 10 Posted March 9, 2015 When activating the alarm, a continuous beep is made. I feel the car senses a door or something is left open but that's not the case. It still activates the immobiliser just does not lock the doors via fob. Luckily I have not de-locked the handles! Quote Share this post Link to post Share on other sites
Hassan. 10 Posted March 9, 2015 Iv read through the manual and cant seem to find anything in there either. Quote Share this post Link to post Share on other sites
Chuggs1 10 Posted March 9, 2015 Not sure what continuous beep is mine beeps 4 Times after the locking beep which on mine signifies something not shut .... Again I have checked everything and all is closed. As for you it started straight after some work where wheels were off. Coincidence i am sure. But will know more on Wednesday Quote Share this post Link to post Share on other sites
