StueyB
Gruvenparts Billet 2.4" Vortech Supercharger Pulley - SOLD
FS: Gruvenparts Billet 2.4" Vortech Supercharger Pulley
Bought for my Vortech V9 Charger but now surplus to requirements.
Never been fitted.
Precision CNC?d from 6061-T6511 aluminum
Perfect match for Vortech Charger shafts.
7-Rib
Spacer included.
Delivery inside the UK included in price.
Avoid US shipping and import charges as well.
List Date: 3/3/2015
For more info, click here to view the original listing: Gruvenparts Billet 2.4" Vortech Supercharger Pulley
SOLD
the-corrado-forum
Mobile friendly version: Gruvenparts Billet 2.4" Vortech Supercharger Pulley
Blurb from Gruvenparts:
Got a boost addiction? Check out these 2.4” diameter supercharger pulleys for Vortech superchargers. This pulley will allow your charger to spin faster, creating more boost and more power.
These pulleys are precision CNC’d from 6061-T6511 aluminum and are sized to precisely match the shaft output on Vortech chargers. These pulleys are 7 rib, but can be used in 6 rib applications that provide enough clearance for a 7 rib pulley (you would just have 1 empty rib). A spacer is included which allows you to install this pulley on VF or AMS kits. Use the spacer with VF kits, dont use the spacer with AMS kits. Pulley rib spacing is 0.140” center to center (for K style serpentine belts).
These pulleys come machined to accept the standard woodruff key found on the Vortech supercharger output shafts.
So I'd say yes.
Willing to do a deal now to clear Pete.
Any idea how much boost this would generate? Don't want any belt slip etc.. I'll need to check offset of my pulley against yours. [ATTACH]81541[/ATTACH]
As you can see mine is non standard but has seen better days
Pulley comes with a washer spacer for VF applications so I would assume you would need to use this to get the spacing correct.
You current pulley looks a lot like the condition of my old 6PSI pulley which was actually causing belt's to wear excessively.
My current 2.4'' VF Pulley makes a stead 10 PSI of boost accordingly to my Autometer Gauge. Much to our surprise I'm not experiencing any obvious belt slip (top end squeal).
Due to your charger being a slightly different model however I wouldn't want to approximate too much. Plenty of online documentation for each charger when I was searching for the same info for my V9 however.
Hi mate. Sorry for the delay. Can you please provide measurements as per the following :
[ATTACH]81562[/ATTACH]
[ATTACH]81563[/ATTACH]
[ATTACH]81564[/ATTACH]
No worries.
I'll do my best to get these measurements asap however it may be week or so as working away from home at the moment.
No worries pal. That's fine as I'm in / out the country for a couple months so won't get chance fit it just yet anyhow.
Any luck mate?
Hey Pete, not yet I'm afraid.
Landed back from holiday yesterday and back to the south coast tonight.
Hope to get to workshop this coming weekend.
If you could drop me a PM Thurs/Friday, that would help remind me.
Still for sale.
However I thought I'd share the pics I sent to Pete recently.
I'm on holiday for a few weeks so will check measurements when I get back mate
Pete's out as it's not suitable for his charger so fully back up for sale again.
Also measured the internal shaft diameter. Approx 20mm ID (19.7-19.9mm).
