Elliot N
Wiring Help!
I've been going through my wiring harnesses and labelling plugs and wires as it has come back from a 'mechanic' in pieces :/ I've found out what most of them are but stuck on a few and was wondering if any of you guys knew, they are all attached in pictures :) its a 1.8 16v KR engine.
http://i1136.photobucket.com/albums/n486/golfmk3tdi1/Mobile%20Uploads/IMAG0467_zpskgl28crx.jpg[/img]
Edited by Elliot N
The wiring in the first second and third pictures seems to go by the ignition coil and the second photo by where the airbox would be.
I'll take a stab at this one.
Yellow wire is for the oil pressure sender, the sender sits on top of the oil filter. The blue/white wire is for and optional oil pressure gauge. The third wire is for the oil temp gauge
