TanVr6
Detailing my Blackberry VR
I would spray some 3-in-1 silicone lubricant on to a cloth & then wipe the spoiler supports in the up position, putting on a thin, even layer. Raise & lower a few times & job done.
spoiler supports don't make a lot of difference, you really need to strip it all apart and lubricate the cables, while you're in there check if they are badly corroded, the design is supposed to separate the support from the drive cables to prevent water ingress but it doesn't seem to work very well and the cables can go rusty jamming the whole thing up
