ryanb1031
*Help Passenger side door won't open !!!
Hi all, i have searched for some threads on corrado doors not working and I've only come across the broken latch problem. I don't believe my latch is broken and the handle is still on the door. Here is the issue:
When i put the key in the door and turn key to open lock, i can visibly see both locks going up (The fuel tank cover also opens) . At this point i can open the driver side door but i can not open the passenger side.:confused:
I tried turning the key on the passenger side door from the outside and the lock goes up but when pulling gone the handle the door doesn't budge. I even tried opening the passenger side door from in side and it still does t budge.
Any ideas on what might be the problem and how i can fix it?
I don't want to keep pulling on the handle which might cause it to break off and i don't want this problem happening to the driver side door. Any help is appreciated.
