modeliuks
Speedometer does not count mileage
Since I bought my 91 Corrado G60 the speedometer haven't calculated mileage, but everything works fine, it shows speed ,temperature, fuel, and revs. And mfa screen almost doesn't work, it is barely visible and some lines are invisible at all. Is my speedometer bad? I have to change it? Or I can somehow fix it?
Hi, is it the electronic or mechanical version?
Sounds like the clocks but maybe worth checking wiring and changing the fuse first just in case there is some high resistance somewhere causing the behavior.
It mechanical version. Today I opened the speedometer and there's broken gear there http://imgur.com/DSImbWk I'm not sure if you can see it but the side is broken. I'm not sure how to fix it, and there was a metal spring that I couldn't get of the shaft http://i.imgur.com/4evBVqe.jpg . This is how clock looks like http://imgur.com/P057omg
Edited by modeliuks
