modeliuks 10 Posted June 14, 2015 When I bought my 91 Corrado G60 prety much everything that was electric in the car wasn't working, I had to drive it to electrician(it started when you pushed it). Electrician forgot to fix power mirrors. How can I fix corrado's power mirrors, fuse is good, none of the mirrors work. Quote Share this post Link to post Share on other sites
Wompa 0 Posted June 14, 2015 Its very often the switch that is the fault. Remove the door card and unplugg the switch. Inside the switch is a board and some cooper strips. Clean them with some alcohol and a eraser. Watch out for the small springs and contacts inside. Remove any old "grease" and reasemble. Mine worked after this! Quote Share this post Link to post Share on other sites
modeliuks 10 Posted June 14, 2015 Thanks, tomorrow I will try this Quote Share this post Link to post Share on other sites
modeliuks 10 Posted June 15, 2015 I cleaned the contacts with sandpaper first and then cleaned it with alcohol. It didn't help. It still doesn't work Quote Share this post Link to post Share on other sites
