VR6 Lee
Corrado heater control
Or if anyone has the bottom cog on the directional dial (on a broken set of heater controls) we could use that instead.
I've got two:
Both are missing a couple of the mounting tabs (appears to be massively common!). The unit on the right on the first picture and seen from behind in the second picture has all the Bowden cable mounting clips intact and is fully functional. The unit on the left on the first picture and seen from behind on the third picture is missing the middle Bowden cable clip (the one that holds the cable that does the windscreen/feet adjustment - again, massively common)
I'm looking for £40 posted for the unit with all the clips intact and £20 posted for the one with the missing clip.
Tom
Edited by Purple Tom
I'm after heater control for late corrado mine is completely had it.
Hi Ron,
I have one that’s fully functional currently fitted in my car.
It does have some plastic welding behind and one mount tab missing and feels delicate, but that could be the cables or flaps.
Once I fit my new one I have I will let you know on here
Regards Graham V
Once it's out of the car I will let you know but thinking £30 as long as its all intact
Hope to do it next week
Regards Graham V
How much do you want for it once it is of.
Hi Ron,
Regards Graham V
Removed without further damage, all working fine just missing cable clip mounts and click springs.
It was the cables and flap causing problem on mine.
See my VR6 1993 surplus parts thread for part no.s
[ATTACH=CONFIG]94663[/ATTACH]
Regards Graham V
Graham thanks I'm at the VW Festival on the Sunday hoping to pick one up from Chris Ferry along with a Steering Wheel. If I have no luck will get back to you. Have you pic of the rear of the unit and are all the parts in the pic included in the £30.
Graham had no luck at the VW Festival at the weekend so will probably take you up on your offer. Will pm you
Sent PM too
All items inc.
[ATTACH=CONFIG]94753[/ATTACH]
[ATTACH=CONFIG]94756[/ATTACH]
