Roger Blassberg 0 Posted July 28, 2015 I have bought a set of under- bonnet foam insulation from Christian (SPRINTER). Excellent product by the way.Now I need to fit it. So some advice please. Firstly any tips on removing the old foam would be helpful. I was thinking of covering the engine bay with a sheet and just carefully scraping the foam off, but I imagine that there will be some old adhesive to deal with. Should I use a solvent? And then to the sticking of the new foam - does the paper backing peel off to expose a self adhesive layer or do I use a contact adhesive? Best wishes RB Share this post Link to post Share on other sites
Jim 2 Posted July 28, 2015 Hi Roger.. I'll probably lock this thread up as removal of old foam has been discussed a lot on here. Here's an example thread: http://the-corrado.net/showthread.php?77862-Bonnet-foam-Removal As for sticking it, from talking to someone this weekend who bought a set of the foam, I believe it does come with a strong adhesive layer under the bit you peel off. Share this post Link to post Share on other sites
