Dec
QPENG - MBE 992 Full plug & Play Engine Conversion Kit
Complete QPENG Plug & Play ECU conversion kit for installing 1.8T 20v engines
Details can be found at: http://www.qpeng.com
This was used installing a AUQ 1.8T into a 1990 VW Corrado and the kit is directly compatible between all 1.8T. The ECU currently has a map for the AUQ 1.8T engine, but maps for all other engine codes are available from QPENG and an be downloaded via the CAN interface in the loom (the sliver plug in the photos).
This has the optional upgraded 2-Stage switched boost control, and has been mapped to 235Bhp.
Also comes with the tacho interface box, so older style RPM gauges will work perfectly.
Comes with Cable throttle body with calibrated throttle position sensor, and also an accelerator cable modified to the correct length for use with a 1.8T engine, and also the inlet manifold which has been modified to take a cable throttle body.
Full kit consists of:
MBE 992B reprogrammable ECU
Full QPENG engine loom (labelled for easy installation)
Dual-stage boost control upgrade
3-Bar MAP sensor
RPM tacho adaptor box
O.E VW cable throttle body with calibrated TPS
Modified throttle cable
Modified inlet manifold for use with cable throttle
All working perfectly, and drove very nicely (was only used over the summer last year, so everything is almost as new!).
Video taken earlier today of the ECU running (cold start with no throttle after sitting in the garage for 3 months!)...apologies for the shaky video quality!
https://www.dropbox.com/s/ratlnfuc560t1v4/20150404_143456.mp4?dl=0
The cost of putting this kit together separately is almost ?1300!
QPENG ECU kit: (?850 + 20% vat) = ?1020
Dual Stage boost control upgrade: (?50 + 20% vat) = ?60
Custom modified inlet manifold: ?65
Throttle body: (?50 + 20% vat) = ?60
Modified throttle cable: ?20
Standard wiring loom for adaption by QPENG: (?50 + 20% vat) = ?60
Description from QPENG:
'Plug and Play' and 'Plug and Play OEM' Engine Management Kits
Do you have the ability to fit and plumb your engine but are put off by the complexities and pitfalls of installing the engine management system? If so the QPEng 'Plug and Play' and 'Plug and Play OEM' engine management kits could be the solution you have been looking for. Available for the 1.8T engines the kits have the following key features:
Simple 'Plug and Play' installation, no cutting or soldering
Total integration of the engine into any Volkswagen Group vehicle including tacho and coolant temp gauge functions
Mapped for maximum power and torque with excellent driveability
Use of original engine sensors, coils packs, injectors and wiring harness allows a ?factory look? conversion and ensures component quality is maintained while avoiding excessive costs
No need to use ECU, Clocks and keys from donor car
Now with free software upgrades for life if you upgrade your engine using OEM parts (1.8T Only)
Includes shift light output
List Date: 8/17/2015
For more info, click here to view the original listing: QPENG - MBE 992 Full plug & Play Engine Conversion Kit
On Sale For: ?699.00
the-corrado-forum
Mobile friendly version: QPENG - MBE 992 Full plug & Play Engine Conversion Kit
