leon263 0 Posted August 30, 2015 Eibach camber adjustment bolts Eibach camber adjustment bolts which will suit any Corrado. New and unused these will allow up 1.75 degrees of positive or negative camber when fitted which just might be enough to save you arch work with your wide front wheels. Simply use one bolt each side in place of the upper strut mount bolts and adjust to your desired setting. Full fitting instructions are on the box. List Date: 8/30/2015 For more info, click here to view the original listing: Eibach camber adjustment bolts -------------------------------------- On Sale For: ?16.00 -------------------------------------- Mobile friendly version: Eibach camber adjustment bolts Go Mobile: Download the free Panjo iOS app now! Share this post Link to post Share on other sites
