DanA
Broken immobiliser touchkey surround
As you can see from the photo its pretty much had it!
Its a Cobra immobiliser, does anyone know if you can get new surrounds?? All the bits seem to pop out of this one, so if i could just get hold of another one it would be easy to sort.
Cheers,
Dan
ah, cheers for that... had a quick search but couldn't find any contact details!
if you can find how much power the led requires you could get a new blanking plate from vag and get an aftermarket led drill a hole wire up and there you go. I am at this point in time changing my clifford red alarm leds in door pin surrounds and dash leds to blue ones to go with the dash lighting.
that's also the immobiliser contact Woody, so he'd need the proper mount to be able to touch the fob onto the contact to start the car... ;)
