leon263
Genesis Audiophile 5.25 inch mid bass speakers.
Here we have an immaculate set of Genesis Audiophile, A13.02, 5.25 mid bass drivers. These are the same depth as the standard door speakers and with very little work would be a direct fit.
As can be seen in the photos there are four lugs on each speaker with holes for the mounting screws. The standard speakers have four lugs with an open slot in each for the mounting screws so it would be necessary to slightly open out the mounting holes and open them to form four slots as per the OEM speaker.
These speakers are rated at 130 watt max, 80 watt RMS input and being Genesis, whose whole ethos was 'sound quality', they are an extremely able and composed speaker which will handle any genre of music at any level with ease.
You would hear a marked improvement even if you only mounted them in the standard door pods, used the standard dash mounted tweeters and ran them off the head unit.
List Date: 9/22/2015
For more info, click here to view the original listing: Genesis Audiophile 5.25 inch mid bass speakers.
This item is no longer available.
the-corrado-forum
Mobile friendly version: Genesis Audiophile 5.25 inch mid bass speakers.
