IainG60
91 Pearl Green G60
Hi Ive just bought my first Corrado and a G60
There's a few issues i would like some advise on if you could.
The front wipers only work on full speed and doesn't stop in the correct position, what could be the reason for this?
The temperature gauge is intermittent and when it does work its only reads 70 max.
The fuel gauge doesn't work, apparently stopped after the lift pump was replaced?
is there a better inter-cooler that can be fitted?
Is there a recommended cone filter that works best?
it already has one but needs replacing.
Many Thanks
Iain
Welcome to the board - no idea how to fix any of that stuff though but in relation to the wipers from previous experience with other cars looks like you need another control unit / lever switch for the steering column.
