Alziboy 10 Posted November 16, 2015 Hi guys + girls, I am currently stuck with what to try next to get this VR6 back onto the road. I have been working my way through a long list of issues and been helped a lot by people with parts however I am really struggling with the ABS system. I have had a faulty pump as there was no fluid coming out of the Rear drivers side calliper only, so I have sent this off to be checked and sure enough the ABS pump was toast and irreparable, so I have fitted another abs pump and still no fluid coming from the calliper. I have chased this all the way back to the pump and there seems to be a 13mm not on the line where as all the others only have an 11mm nut. When I disconnect and pump the brake fluid comes out of every other line apart from the one to the rear drivers side, I am now wondering if I am just that unlucky that I have had 2 pumps with exactly the same fault both times or is there something else I am over looking. Any ideas would be greatly appreciated. I am located in S****horpe also if someone has VAG COM in the area that might be able to work the pump that would also be appreciated Thanks Alan Quote Share this post Link to post Share on other sites
