Justin Doneghy 10 Posted December 4, 2015 (edited) I am starting to think we all have a real serious illness. That or we just love tossing money into that dark hole called a Corrado :bonk:. My name is Justin and i own a 93 SLC. (dont dis my jam):cheers: she is a work in progress. the body was real rough when i got her. No rust just dents in bad spots. That all changed this year along with a list of mods. This is not the car I am needing help with. IT is my 90 G60. 3 years back I picked her up and just loved that car! Started to just do normal things like vac lines. Rod bearings. New air cone ect...well I SUCKED A RAG INTO THE Gladder :g60:...yes I know. Please dont ask. It hurts to remember the sound she made. After flipping out and going from what swap I wanted to do from putting a VR in her, to a 2.8 fsi and now I have on a stand a 2.0 9A. 83mm wiseco pistons and rods. HD lifters. High rev springs. BBM Distributor block off plate. Trigger wheel. Solid head gasket. Pnp. and the turbo oil line. I am lost now and looking for some guidance. I want to do coil packs and stand alone because i just dont want to fuss with digi since I am a bit lost on mega squirt. That is one major thing I am needing help with. Also whats a good turbo size? I would like to get around 450 with water meth. I have the stock PG engine. Parts needed if i am going stand alone? What version of MS is needed? For the trans I am getting together an o2j shifter swap and would like opinions on LSD...Quaife vs.Peloqin? Will a TDI 5th gear be needed? Lots of info needed guys/gals and i am a sponge right now. Happy Holidays everyone. Edited December 4, 2015 by Justin Doneghy Quote Share this post Link to post Share on other sites
Justin Doneghy 10 Posted December 4, 2015 Also if anyone has parts I will be needing please lmk. I would like to have this done by spring. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted December 4, 2015 Hi, I've got loads of bits, having done a few turbo-16v engines in the past, what do you need? turbo? injectors? the list will go on and on mate... Quote Share this post Link to post Share on other sites
Justin Doneghy 10 Posted December 4, 2015 i will pm you in the am. thanks. Quote Share this post Link to post Share on other sites
