blacktopsurfer
Dashboard indicator sticking on
I have a problem I'd need some help with if you would be so kind. Im finishing up my corrado project. With the dash now installed the indicator light for the drivers side is on constantly as a dim light and when you indicate either way only that side flashes. This is on the electronic dash. Now when I put the mechanical dash in the indicators work perfect. Any ideas as to why the electronic dash is playing up? I have 2 electronic dashboards and both are coming up with the same problem. Thank you Pete
