delfinis38
Fog and indicator removal
Put a flat head screwdriver between the fog and indicator. That should then pop out the indicator. pull it towards the left side if its the drivers the right if its passenger side. Undo the light bulb connector, next you should see two screws in the centre of the plastic surround. Unscrew these then the surround and fog light should come out as one.
I reckon you can even pop the indicators out with your fingers to be honest.. not too much force required at all :)
Quite possibly... I do love rusty screws.... New stainless on order, give me time to polish.
