delfinis38
Waxoly
While I've got the front arch liners out, having a general clean. Am wanting to put some better protection on the inner wings... Is Waxoyl the best option.
I used mainly dinitrol products
https://dinitrol.co.uk/ClassicCar.aspx
The inner wings (on car chassis) are covered in quite a thick layer of rubbery stonechip and then painted bodycolour, so unless yours is damaged i would leave as much of that on as possible. Worth testing all the products first, as i had trouble with some thing not drying over the top of the existing stonechip.
I'd chisel off any areas that look odd (its hard to tell where the rust is underneath as the stonechip is so thick), treat the rust and then try to build up the rubbery stone chip again. Then you could add a hard wax over that. Or just paint it.
