delfinis38
Headlight washers
Are you going to fit or are you removing? I dont understand the question.
If you are fitting, then yes. How are you supposed to fit them without drilling?
I hope you have the right water bottle...
You will route the hose in the front up to the washers.
Not difficult to mount, only time comsuming.
The washers should only spray the headlights when you have the headlight switch on... a relay will controll that.
