BeliRican
Antenna help ASAP please
I broke my Corrado vr6 antenna. I've already ricieve the new one. But doesn't know how to install it. Which interior parts do I need to take of for the installation? Process, etc? Thanks
If you open the tailgate, you can remove the plastic trim at the back edge of the roof lining (a bit awkward as you sometimes need to loosen the trim going up the C-pillars. Then you should be able to pull the roof lining down a little and get to it from underneath
And and after I get it from underneath, how do I connect it there's a long cable do I have to strip the whole interior trim and dash if so how? QUOTE=Jim Bowen;1102602]If you open the tailgate, you can remove the plastic trim at the back edge of the roof lining (a bit awkward as you sometimes need to loosen the trim going up the C-pillars. Then you should be able to pull the roof lining down a little and get to it from underneath
