Arnie Clark
drivers door wont open from outside and inside
drivers door wont open from inside or outside ive seen posts about outside not opening but not any from both inside and out cheers:scratch::bonk: think some one tried to steal it tbh:2gunfire::bad-words::bad-words::bad-words:
Your door latch mechanism will be stuck down in the down position inside the door. It can do that when you try to open the door with it locked and it then gets stuck if its old. Mine was like that for years! You'll need to take the outside window trim off and try and fish/lift the latch back to the operating position. Once its up, unlock the car with the fob and try again.
