WillMK7
Hazards fault
Evening chaps, I do apologise if this is in the wrong question. But in a bit of an odd one.
Today, unfortunately, the Corrado failed its MOT... for 4 individual, non concerning reasons thank god! No corrosion yay!
However, the hazard warning lights are faulty... I've never even used them since I got the car, so I had no clue that they weren't working. But what happens when you de-press the button, the left hand lights will function as they're meant to; but the right hand lights will not, they work individually when indicating ect. The indicator light on the dash doesn't even display. I figure its not a relay, as the whole lot wouldn't work. SO any ideas as to what it can be? I've ordered a new stalk and hazard switch assembly, do you think this will fix it? Has anyone come across this before?
Thanks in advance!
Will
