Mike Hall 10 Posted May 25, 2016 Hi my g60 clocks haven't worked since I got the car. To start with the speedo wasn't working or any of the data on the MFA other than the boost pressure test, but tacho worked as did the LEDs. A couple of days ago my tacho and leds also stopped working and the LCD displays have every segment lit up too. I've checked the earth for the clocks and reseated the cables in the back too.Some of the wiring has been spliced near the ecu and the clocks are the 15litre version but my car is a 91 so I believe this is wrong. Any ideas? Thanks! Sent from my Nexus 6P using Tapatalk Quote Share this post Link to post Share on other sites
MZpog 10 Posted May 25, 2016 Where you at Mike? I have some spare clocks you could try if your nearby. Quote Share this post Link to post Share on other sites
Mike Hall 10 Posted May 25, 2016 Hey that would be great thank you, but I'm near Hull so I'm probably out of the way. Sent from my Nexus 6P using Tapatalk Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted May 25, 2016 I had same problem. Fitted a different set and everything is working ok now. Quote Share this post Link to post Share on other sites
MZpog 10 Posted May 25, 2016 Mike Hall said: Hey that would be great thank you, but I'm near Hull so I'm probably out of the way. Sent from my Nexus 6P using Tapatalk At least an hour away from me so almost as much in fuel as buying some. Guessing the clocks you have had the digital odometer and would flog my set if you want. I didn't use them as they show about 100k, rather than mine at 185. Just used them a few miles to test the spoiler function (which had died in my original clocks - transistor fixed them) and everything worked (possibly with exception of the trip counter). PM me if you're interested. Quote Share this post Link to post Share on other sites
