culshaw 1 Posted August 11, 2016 (edited) Hi there I'm after this, to see if it fixes a problem I'm having. Anyone got one laying about? Edited August 11, 2016 by culshaw can't ****ing spell. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 11, 2016 hi m8 IIRC they are very expensive from VW, or were if they are now obselete, as they only sell the entire section including the attached air housing when i changed the PCV on my VR i got it from ford - as the v6 galaxy uses the very same part but ford sell it on its own let me check my build thread for a part number for you..... Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 11, 2016 cheers but i need the pipes not just the valve itself as its been butchered Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 11, 2016 cheers but i need the pipes not just the valve itself as its been butchered looking at the ford invoice it shows 7364573 & was £32.50+vat sorry i should have been more clear - i understand you have the large plastic air intake section but need the hoses which connect the PCV to such VW only sold the PCV with all of the air intake section you already have (IE the large plastic section which goes to the MAF & the TB) ford sell just the PCV & likely sell the connecting hoses too either way IIRC VW price was about £90 & as such i am sure you can get the hoses & a couple of jubilee's, or ones that can be made to fit, for less than £60 Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 11, 2016 thanks pal, i'll see what i can sort out Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 11, 2016 thanks pal, i'll see what i can sort out no problem - good luck Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 11, 2016 This looks the ticket for £40.. http://www.ebay.co.uk/itm/VW-GOLF-VR6-Engine-Breather-Hose-PCV-Valve-Diaphragm-7M0-129-101-/232040591744?hash=item3606b27180:g:DFAAAOSwaB5Xpf8F Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted August 11, 2016 This looks the ticket for £40.. http://www.ebay.co.uk/itm/VW-GOLF-VR6-Engine-Breather-Hose-PCV-Valve-Diaphragm-7M0-129-101-/232040591744?hash=item3606b27180:g:DFAAAOSwaB5Xpf8F good find :) Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 11, 2016 Do you need the vac lines to inlet and carbon canister etc? Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 11, 2016 Do you need the vac lines to inlet and carbon canister etc? I need everything that is in the picture at the top, the PCV valve on mine has been deleted and bodged together into the elbow via a straight line pipe Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 11, 2016 That's what I thought. The reason I ask is that there is more to it than pictured above. There is a series of lines that join the pcv, inlet and carbon canister. Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 11, 2016 That's what I thought. The reason I ask is that there is more to it than pictured above. There is a series of lines that join the pcv, inlet and carbon canister. ok, do you have a picture around? Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted August 12, 2016 The t piece here Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted August 12, 2016 Found a cheaper one while looking on ebay today http://www.ebay.co.uk/itm/Genuine-Vw-Golf-Mk3-VR6-Engine-breather-valve-7M0128101-and-pipework-Volkswagen-/191943226345?hash=item2cb0b533e9:g:FDMAAOSwMtxXq6Ra Quote Share this post Link to post Share on other sites
culshaw 1 Posted August 13, 2016 Found a cheaper one while looking on ebay today http://www.ebay.co.uk/itm/Genuine-Vw-Golf-Mk3-VR6-Engine-breather-valve-7M0128101-and-pipework-Volkswagen-/191943226345?hash=item2cb0b533e9:g:FDMAAOSwMtxXq6Ra thanks Jim The t piece here found this earlier.... ffs Quote Share this post Link to post Share on other sites
