vwfil
Radio wiring
Does anybody have a complete wiring diagram for the corrado radio?
I've sorted out the audio side and I've re-attached the iso plugs as they had been removed but I have no live or switch live from the power cables. I've checked the fuse board and I have no blown fuses so I'm wondering where the switch and permanent cables come from so I can check the other ends.
thanks
phil
thanks
phil
I had a problem with my radio switched live and it was an ignition switch problem. but it doesn't explain your constant live.
  g0ldf1ng3r said:
do you have a bentley manual? i think they have a diagram in there but im at work so cant check
could try googling....as this came up http://media.corrado-club.ca/images/vr6_corrado-1/EKTA-StereoWiring.gif
though it is canadian linky
cheers @g0ldf1ng3r yeh that's the diagram I used to resolder n heat shrink the audio and power side plugs back on that's complete but I need to know where the source end of the power cables is so that I can find out why there is no power. im assuming both will run from the fuse board both permanent and switched but I have no idea which terminals to look for.
delfinis38 do you know where on the ignition the radio connects? I know its a brown cable with a red marking but would rather not have to pull my whole dash apart to trace it ha ha
oh sorry i misunderstood
fuse board diagram - http://img.photobucket.com/albums/v640/a777ovl/etka/corrado/fusebox.jpg
  delfinis38 said:
It goes in the back of the ignition plug... You can split the cowling to check.
cheers man will take a look when I get home in 2 weeks! try n sort out the permanent aswell
